Natural Convection Heat Transfer
I'm using the Conduction and Convection application mode to model the heat transfer resulting from a hot plate in an upward contact with water.
Does anyone know the expression of the velocity of the fluid for natural convection in these conditions ?
Thanks.
Nicolas
4 Replies Last Post Aug 19, 2009, 9:27 p.m. EDT
David Wenger Certified Consultant
Posted: 2 decades ago Jul 21, 2009, 12:46 p.m. EDT
The velocity depends on the heat transfer rate and the difference of density and temperature in your system. You need a heat transfer coefficient which is f(Re,Pr,Gr,...) and a temperature-dependent expression for the density or the Boussinesq-approximation.
Regards
David
www.comsol.de/company/consultants/wenger
The velocity depends on the heat transfer rate and the difference of density and temperature in your system. You need a heat transfer coefficient which is f(Re,Pr,Gr,...) and a temperature-dependent expression for the density or the Boussinesq-approximation. Regards David www.comsol.de/company/consultants/wenger
Posted: 2 decades ago Jul 21, 2009, 2:31 p.m. EDT
There is a model in the model gallery which is very similar to my problem : free convection in a water glass
comsol.com/showroom/gallery/195/
Unfortunately, I don't find it in the Model Library. Is there another way to have access to this model ?
Nicolas
There is a model in the model gallery which is very similar to my problem : free convection in a water glass http://comsol.com/showroom/gallery/195/ Unfortunately, I don't find it in the Model Library. Is there another way to have access to this model ? Thanks Nicolas
Posted: 2 decades ago Jul 21, 2009, 3:01 p.m. EDT
Regards
David
Thanks.
[QUOTE] The velocity depends on the heat transfer rate and the difference of density and temperature in your system. You need a heat transfer coefficient which is f(Re,Pr,Gr,...) and a temperature-dependent expression for the density or the Boussinesq-approximation. Regards David www.comsol.de/company/consultants/wenger [/QUOTE] Thanks.
Posted: 2 decades ago Aug 19, 2009, 9:27 p.m. EDT
hi, someone have or know where I can found the solution manual of book Convection Heat Transfer, third edition of author Adrian Bejan, because I need very much in my pos-graduate. thanks.
my e mail is augusto_bassan@yahoo.com.br
hi, someone have or know where I can found the solution manual of book Convection Heat Transfer, third edition of author Adrian Bejan, because I need very much in my pos-graduate. thanks. my e mail is augusto_bassan@yahoo.com.br
