Jan 30, 2012, 4:06 p.m. EST
try something like:
Define an interpolation function interp1(R) as the deformation you desire w.r.t. a variable R=sqrt(X^2+Y^2) I assume here your deformation is regular in X,Y.
Set up your solid model (or shell), add a boundary pressure load Fp acting on the membrane
Define a variable R = sqrt(X^2+Y^2) (upper case on the material frame pls check for 3.5)
Define an integration on the membrane domain where it deforms
Define a ODE (Global equation) with Variable Fp and equation intop1(w-interp1(R)) = 0 intop1() in 3.5 is a boundary integration coupling (if I remember right, names have changes)
Solve
this should work, it will get an average pressure load that deforms the membrane up to the interp(R) values, in a least square way
If you have the solid/structural doc in 3.5, you can check the example of the torque load, this uses a similar approach to apply a torque on a bar
try something like:
Solve
Feb 1, 2012, 11:21 p.m. EST
Thank you for reply.
But I am still confused.
For a 2D case. If the curvature R is fixed eg. 1cm. Do I still need to define a variable R=sqrt(x^2+y^2). If this related to the membrane position (x,y).
For Fp, which direction should it be, or in both of x and directions.
Also could you tell me what the w is in equation intop1(w-interp1(R)) = 0.
Thank you.
Thank you.
Feb 2, 2012, 1:42 a.m. EST
sorry but you did not give that much explanations about your model options, I was in 3D, you can perfectly analyse this in 2D with membrane deformation in Z, you are right and it solves quicker ;)
w is the displacement in Z (you have u,v,w for the resulting "solid/structural) deformations along X,Y,Z respectively
