Power from point dipole to port boundary
Posted May 6, 2020, 5:48 a.m. EDT Wave Optics Version 5.5 0 Replies
Hello. I am attempting a simulation to determine the power arriving from a point dipole to ports in a waveguide. This is a 2D simulation using a frequency domain study in the wave optics module.
To do this, I am using an Electric Point Dipole node (with coupling structure) close to a simple rectangular waveguide. The boundaries at the ends of the waveguide are numeric ports, set to "off". After simulating, I can see the electric field (via 2D surface plot) in the waveguide (all the way to the ports), but am strugging to find a way to show the power arriving from the dipole. Or quantify this field in any way, actually.
I notice that when I run a similar simulation with one port set to "on", there are additional plotting options such as transmittance and S-parameters. These are absent when both ports are "off", and I can only plot the mode index and propagation constant, found from the boundary mode analysis.
Can someone point me in the right direction? Am I missing something? I'm happy to provide more details (and an MPH file), if that helps.
Also, I've noticed I cannot animate this field (from the dipole) in the 2D plot. When I do a dynamic data extension, I am left with zero field everywhere. This is at odds with the solution. Again, I am likely missing something.
Cheers!
Hello David Northeast
