Particle tracing for fluid flow: wall interaction limit!
Dear Support Center,
I performed a fluid flow simulation (turbulent, k-epsilon) and then a particle tracing one. I employed 1000 particles and used "bounce" as a wall condition. This is fundamental to me. However, at the end of the simulation, I obtain a warning stating:" Some particles have been removed from the simulation because maximal number of wall interactions within one time step has been reached." Increasing the number of particles to 5000, I also obtain the following:" Some particles have been removed from the simulation because of a failure in finding the wall intersection."
What should I do? Thank you very muhc. Best regards, Andrea Giordano.
2 Replies Last Post Jun 26, 2020, 2:58 p.m. EDT
Hello Andrea Giordano
Posted: 4 years ago Jun 15, 2020, 2:09 a.m. EDT
Hello Andrea, I'm facing the same kind of problems. Did you find a solution for your problem?? If so, could you please explain me how you did it??
By the way, do you know how to generate a residence time distribution curve?? I've been trying it for days, but I cannot overcome this problem.
Thanks in advance for any answer. Jhoan
Hello Andrea, I'm facing the same kind of problems. Did you find a solution for your problem?? If so, could you please explain me how you did it?? By the way, do you know how to generate a residence time distribution curve?? I've been trying it for days, but I cannot overcome this problem. Thanks in advance for any answer. Jhoan
Hamid Rezaei University of British Columbia / Renewable Solid Fuel
Posted: 4 years ago Jun 26, 2020, 2:58 p.m. EDT
Please let me know if you could find the answer of this issue. I have the same problem.
Hamid Rezaei, Ph.D.
Research Scientist at the University of British Columbia (UBC)
R&D Director at CanDry Technologies Inc.
Adjunct Faculty at New York Institute of Technology (NYIT) – Energy Management Department
Office 604 827 3419 | Cell 778 707 0866
h
