Two Phase flow fluid structure interaction.
I am relatively a new user with COMSOL. can anyonw suggest module for two phase fluid-structure interation. The two phase flow is liquid (water) and gas (nitrogen). I am trying to model with fluid structure interaction with bubble flow model as two phase which does not give me and results on stress due to bubble flow. Please advice!
3 Replies Last Post Aug 20, 2020, 12:45 a.m. EDT
Posted: 5 years ago May 21, 2020, 1:35 p.m. EDT
Updated: 5 years ago Aug 20, 2020, 8:39 a.m. EDT
Hello Viren,
Perhaps this model of two-phase flow with fluid structure interaction could help, though it does not involve a bubble per se.
Jeff Hiller
Hello Viren, Perhaps [this model](https://www.comsol.com/model/two-phase-flow-with-fluid-structure-interaction-4515) of two-phase flow with fluid structure interaction could help, though it does not involve a bubble per se. Best, Jeff
Posted: 5 years ago May 23, 2020, 7:00 a.m. EDT
Thank you Jeff,
I am working using the two phase FSI model you sent me as an example. that was very helpful!!
Thank you Jeff, I am working using the two phase FSI model you sent me as an example. that was very helpful!!
Posted: 5 years ago Aug 20, 2020, 12:45 a.m. EDT
Dear Viren, Greetings!!
Are you able to simulate the problem which you have mentioned in your previous comment? Can you Please share your experience? I am also trying to explore the same with bubbles? Thank you Arpit
Dear Viren, Greetings!! Are you able to simulate the problem which you have mentioned in your previous comment? Can you Please share your experience? I am also trying to explore the same with bubbles? Thank you Arpit
