COMSOL expression evaluation
Hi all,
In COMSOL I am using two expressions to calculate a certain parameter, and the objective is to pick the one that under given conditions gives a result, which is a real number and 0<=x<=1). I can easily plug a MATLAB routine to do the assesment and pick the value calculated from either of the two expressions, but I always consider the use of MATLAB from COMSOL as last resort, so maybe there is a way to do it with some smart formula in COMSOL?
Any help will be very much appreciated,
Mike
4 Replies Last Post Jul 4, 2012, 3:45 a.m. EDT
Posted: 1 decade ago Feb 10, 2012, 2:46 a.m. EST
Mike,
you could try to use boolean expressions, like
x*(x>=0 & x<=1) This would result in the value of x between 0 and 1 and 0 elsewhere.
Cheers
Edgar
Mike, you could try to use boolean expressions, like x*(x>=0 & x
Posted: 1 decade ago Feb 10, 2012, 12:18 p.m. EST
Thanks. This is better than nothing.
Cheers, M.
Thanks. This is better than nothing. Cheers, M.
Posted: 1 decade ago Jul 3, 2012, 11:15 a.m. EDT
Hi Edgar,
Is it x*(x>=0 & x<=1) OR x*(x>=0 && x<=1) ?
Hi Edgar, Is it x*(x>=0 & x=0 && x
Posted: 1 decade ago Jul 4, 2012, 3:45 a.m. EDT
have you read te help on "Special Operators" and "Unary and Binary Operators"
seem to go more towards && and || in COMSOL;)
Hi have you read te help on "Special Operators" and "Unary and Binary Operators" seem to go more towards && and || in COMSOL;) -- Good luck Ivar
