Periodic Conditions
Hello everyone,
I'm trying to solve a problem with periodic boundary conditions. If I set periodic conditions with the type of continuity on a geometry of a cube, and then a prescribed displacement on a face, then the cube moves in space, but does not experience deformation because the displacement of 2 opposite faces is equal.
Does anyone know how i can set periodic conditions such that the the cube will experience deformation?
In the model library of Comsol there is an example of Floquet periodicity, but I haven't seen one of continuity...
3 Replies Last Post Feb 15, 2012, 7:30 a.m. EST
Posted: 1 decade ago Feb 15, 2012, 2:14 a.m. EST
for me it sounds like you have "antiperiodical" loads, but you want symmetry, no ?
Hi for me it sounds like you have "antiperiodical" loads, but you want symmetry, no ? -- Good luck Ivar
Posted: 1 decade ago Feb 15, 2012, 4:40 a.m. EST
Well, I want to set it up so that
U_right - U_left = (F - I ) *X
where F is the deformation gradient, U_left and U_right are the displacements of the left and right faces of the cube, I is the identity tensor and X is the distance between the faces.
However, i'm not sure of how to impose this condition...
Well, I want to set it up so that U_right - U_left = (F - I ) *X where F is the deformation gradient, U_left and U_right are the displacements of the left and right faces of the cube, I is the identity tensor and X is the distance between the faces. However, i'm not sure of how to impose this condition...
Posted: 1 decade ago Feb 15, 2012, 7:30 a.m. EST
I believe that is what the "solid" physics "Periodic condition BC" imposes (the underlaying equation is slightly cryptic with "if" and "src & dst" names).
Then up to you to decide how many DoF you constrain, and how they are aligned w.r.t the global coordinate transform
Hi I believe that is what the "solid" physics "Periodic condition BC" imposes (the underlaying equation is slightly cryptic with "if" and "src & dst" names). Then up to you to decide how many DoF you constrain, and how they are aligned w.r.t the global coordinate transform -- Good luck Ivar
