Transport of Dilute Species coupled to laminar flow
I am trying to couple the transport of dilute species and the laminar flow modules. However, I receive an error every time I try to sole for the dilute species (study 2 in my model).
What am I doing wrong?
Attached is the model file.
Thanks!
MRW
5 Replies Last Post Jun 17, 2012, 1:14 p.m. EDT
Posted: 1 decade ago Feb 15, 2012, 2:50 p.m. EST
Hi!
Study 2 should have some solved value for flow. Now it is using initial expression. Change Solver 2 => Dependent Variables => Method => Initial expression to solution and select Solution to Solver 1.
Best regards
Tero
Hi! Study 2 should have some solved value for flow. Now it is using initial expression. Change Solver 2 => Dependent Variables => Method => Initial expression to solution and select Solution to Solver 1. Best regards Tero
Posted: 1 decade ago Feb 15, 2012, 4:06 p.m. EST
Hi Tero,
That worked, thank you.
Do you know if there is a way to change the properties of the dilute species?
Thanks!
MRW
Hi Tero, That worked, thank you. Do you know if there is a way to change the properties of the dilute species? Thanks! MRW
Posted: 1 decade ago Feb 16, 2012, 11:35 a.m. EST
Hi!
What do you mean by changing properties? Changing bulk material or diffusion?
Br Tero
Hi! What do you mean by changing properties? Changing bulk material or diffusion? Br Tero
Posted: 1 decade ago Feb 17, 2012, 9:46 a.m. EST
I want to change the shape of my particles (the dilute species). However, I think I need to use a different type of physics.
Thanks!!
I want to change the shape of my particles (the dilute species). However, I think I need to use a different type of physics. Thanks!!
Posted: 1 decade ago Jun 17, 2012, 1:14 p.m. EDT
The diffusion coefficient (D) is the only parameter that you can change. Please try it. I also do some research on this aspect. I am also a new one....
Thanks!!
The diffusion coefficient (D) is the only parameter that you can change. Please try it. I also do some research on this aspect. I am also a new one.... [QUOTE] I want to change the shape of my particles (the dilute species). However, I think I need to use a different type of physics. Thanks!! [/QUOTE]
