4 years ago
Jun 13, 2020, 11:52 a.m. EDT
Hello Mugdha,
You were missing a pressure point constant which I have added.
Also, your values on the inlet should be either mass controlled or velocity controlled.
Use really small values as I have done as the volume inside the computation exceeds the pressure limit resulting in chocking the system.
The time settings were also too large; try reducung them a little.
Good Luck
Hello Mugdha,
Good Luck
4 years ago
Jun 13, 2020, 12:13 p.m. EDT
Hello Mugdha,
Good Luck
Thank you so much for the feedback! I really appreciate it. I will try implementing these solutions.
>Hello Mugdha,
>Good Luck
4 years ago
Jun 13, 2020, 12:32 p.m. EDT
Here you go.
4 years ago
Jun 14, 2020, 1:24 p.m. EDT
With your model I am getting this error:
Recoverable error in residual, but solver could not recover.
Time: 0.0064000000000000003 s.
Were you able to get a solution?
I will update if I find a solution.
Thank you
Thank you
