absorbing boundary condition for heat transfer problem
Posted Feb 18, 2012, 4:25 a.m. EST 6 Replies
I do not really understand you there: as for me a heat "wave" cannot bounce off a boundary, because the heat equation (diffusion PDE) cannot develop standing "waves" in the sens of EM waves. For that you need a second derivative equation type phenomena.
You can add a "thin feature" to represent some properties, but I'm not aware of HT "infinite elements", perhaps theyy xst for stationry cases, anyhow how to handle that correctly in transient HT ? within the heat diffusivity length you will have transient effects happening, that a "bulk" infinite layerwill not express correctly without quite some equations.
What about adding some material or a non linear heat exchange on your boundary
are you sure you catch the thermal gradient, are aou respecting the dz<sqrt(alpha*dt) where dz is the mesh size perpendicular to the thermal gradient, and dt is the smallest time step you have the solver doing for you, while alpha=k/rho/Cp is the heat diffusivity.
These are the mesh conditions for HT diffusion equation mesh sampling in transient. In MEMS sizes it can be very demanding on mesh density. I often use boundary layer mesh elements for this.
If you are not ceraful, you will even observe "negative" temperatures, which are not really physical
Check the FORUM on HT and gradients of T Nagi has given excellent advises on several of these threads
I could have got the <> mixed up, but I do not think so, or was it wrong in the other tread ?
The original threead was this one:
www.comsol.com/community/forums/general/thread/16808/
but here the formula of Nagi is related to dt>... still by inverting you get dz<....
For the rest of your questions, you should find the replies in this interesting thread ;)
I am wondering if I can define an absorbing boundary condition for a transient ultrasonic wave propagation problem (let's say in a 2D plane strain transient module). The option certainly doesn't come up in the boundary conditions pulldown menu. I wonder if there is a trick.
Thanks!
Deb
Suggested Content
- FORUM heat transfer
- KNOWLEDGE BASE Solving Models with Step Changes to Loads in Time
- BLOG Modeling the Pulsed Laser Heating of Semitransparent Materials
- KNOWLEDGE BASE My Flux Calculation Seems Wrong
- FORUM Heat transfer in multilayer / Overlapping problem
