some general question about step setup
Hi!
I try to model a process of beam vibration, where I apply the linear displacement to the end of beam and then remove this displacement, because I did not define any damp in this model, the beam should vibrate freely.
I tried the following:
I built two studies of time-dependence, one for applying the displacement, the other for vibration. Specificly, I run the study one then run the study two, in this process where I take study one's results as study two's initial condition.
Actually it does work. But it seems not very convinient, because before I run study two I have to disable the prescribed displacement which I defined for study one.
I wonder whether I can make only one study including two steps for the whole process and how I can deal with this problem.
Thank you very much!
4 Replies Last Post Feb 24, 2012, 3:21 p.m. EST
Posted: 1 decade ago Feb 24, 2012, 2:40 p.m. EST
you can define step-function that goes from your load value to zero (make sure it's somewhat smooth). Then define your load as function of time using the step-function created earlier.
Posted: 1 decade ago Feb 24, 2012, 3:13 p.m. EST
or you replace the first time series study by a steady state with a boundary laod of the type F=10N*(t==0). Then do not forget to add a Parameter with t=0[s] then you can run both studies (with the time series using the ss study as initial conditions)
Hi or you replace the first time series study by a steady state with a boundary laod of the type F=10N*(t==0). Then do not forget to add a Parameter with t=0[s] then you can run both studies (with the time series using the ss study as initial conditions) -- Good luck Ivar
Posted: 1 decade ago Feb 24, 2012, 3:18 p.m. EST
thank you! I will try it as your suggestion
Posted: 1 decade ago Feb 24, 2012, 3:21 p.m. EST
thank you! you mean I can define another function which is for my second part. I will try it.
