Cut Line 3D Step Size
Hey guys,
I'm new to COMSOL and am using the Structural Mechanics module for a undergrad physics research project this summer. I've applied a Cut Line 3D to the axial center of a cantilever, and I'm currently trying to adjust the step size of the output file to view parameters such as principal stresses and strains along the line's path. How can I achieve a discrete step size in my path length (even size between entries in X column) when exporting this data? Here is my current export data that I brought into a table:
https://imgur.com/a/hw7pVBJ
Thanks in advance, Ben
1 Reply Last Post Jul 7, 2020, 9:33 p.m. EDT
Posted: 5 years ago Jul 7, 2020, 9:33 p.m. EDT
Updated: 5 years ago Jul 7, 2020, 9:47 p.m. EDT
The following will apply if you are generating your table of the data along a Cut Line 3D by exporting the numbers from a plot (e.g., a "line graph") of that data. So create such a plot, so you can see what I am talking about. Then, find the "Quality" pull-down settings under Settings, Line Graph. Changing the Resolution will change the number of points in the plot. See example images attached, which should help to clarify this.
Note: The attached image isn't set up to generate a fixed step size, but it lets you adjust the number of points sampled along the cut line after the FE model has completed running. If you want a fixed (constant) step size, you might want to try changing the Positioning setting from "In Data Points" (under Coloring and Style) to "Interpolated," and then specify the number of points you want to be in the sample. Then "Export" the plot to create your table entries.
The following will apply if you are generating your table of the data along a Cut Line 3D by exporting the numbers from a plot (e.g., a "line graph") of that data. So create such a plot, so you can see what I am talking about. Then, find the "Quality" pull-down settings under Settings, Line Graph. Changing the Resolution will change the number of points in the plot. See example images attached, which should help to clarify this. Note: The attached image isn't set up to generate a *fixed* step size, but it lets you adjust the number of points sampled along the cut line after the FE model has completed running. If you want a fixed (constant) step size, you might want to try changing the Positioning setting from "In Data Points" (under Coloring and Style) to "Interpolated," and then specify the number of points you want to be in the sample. Then "Export" the plot to create your table entries.
