How to cut the boundary with the geometry imported by interpolation function
Hi, everyone
I want to import the irregular geometry model to COMSOL and I have imported the text file, the function diagram is rectangular but the text file I imported just have some coordinates of the rectangular. When I created a parametric surface, it also was a rectangle, I just want to display the coordinate image that I typed in( circled in red ), how do I crop the resulting parametric surface?
Best regards Xiaowen
1 Reply Last Post Jul 21, 2020, 9:33 a.m. EDT
Posted: 5 years ago Jul 21, 2020, 9:33 a.m. EDT
Hello Xiaowen,
You can create a prism that intersects the parametric surface to trim it.
To create the prism, you can draw a parametric curve in a workplane, and then extrude that shape into a 3D prism.
Jeff Hiller
Hello Xiaowen, You can create a prism that intersects the parametric surface to trim it. To create the prism, you can draw a parametric curve in a workplane, and then extrude that shape into a 3D prism. Best, Jeff
