Draw elliptical cylinder
I am having problems drawing an elliptical cyllinder.
What is the equations for workplane?
Best.
1 Reply Last Post Aug 11, 2020, 2:34 a.m. EDT
Magnus Ringh COMSOL Employee
Posted: 5 years ago Aug 11, 2020, 2:34 a.m. EDT
Updated: 5 years ago Aug 12, 2020, 4:24 a.m. EDT
It should be straightforward: Add a Work Plane node in a 3D geometry. Click the Plane Geometry node under the Work Plane node, and create an ellipse of your choice in the work plane. Then right-click the Work Plane node and choose Extrude. In the Extrude node's settings, specify an extrusion distance and then build the geometry.
Magnus Ringh, COMSOL
Hi, It should be straightforward: Add a Work Plane node in a 3D geometry. Click the Plane Geometry node under the Work Plane node, and create an ellipse of your choice in the work plane. Then right-click the Work Plane node and choose Extrude. In the Extrude node's settings, specify an extrusion distance and then build the geometry. Best regards, Magnus Ringh, COMSOL
