Movement of bead in flow
Hi, I would like to (in a first step) model the movement of a bead in flow. This would be very similar to the demo here : https://www.youtube.com/watch?v=iyA5UiBJY0Q
Except that in this case the bead would not be in a fixed position but convected by the flow. Any pointer to how to do that ?
Thank you very much.
2 Replies Last Post Aug 24, 2020, 10:09 a.m. EDT
Posted: 5 years ago Aug 23, 2020, 4:28 a.m. EDT
Hello Nicolas,
Please refer this blog:
https://www.comsol.com/blogs/simulating-fluid-structure-interaction-in-a-ball-check-valve
Hope it solves your problem.
Regards, Ismail
Hello Nicolas, Please refer this blog: https://www.comsol.com/blogs/simulating-fluid-structure-interaction-in-a-ball-check-valve Hope it solves your problem. Regards, Ismail
Posted: 5 years ago Aug 24, 2020, 10:09 a.m. EDT
Hello Nicolas,
Depending on what information you are trying to get out of your modeling, a particle tracing approach may be simpler that an FSI approach. The Particle Tracing Module can compute the trajectories of beads in a flow.
Jeff Hiller
Hello Nicolas, Depending on what information you are trying to get out of your modeling, a particle tracing approach may be simpler that an FSI approach. The [Particle Tracing Module](https://www.comsol.com/particle-tracing-module) can compute the trajectories of beads in a flow. Best regards, Jeff
