Main toolbar has disappeared 4.2
I've a problem with the 4.2 COMSOL version, the main toolbar has disappeared, I don't know if I did something to cause it, I mean, I didn't erase any file nor anything form my machine.
I work in Mac OS X platform, if somebody knows how to fix it, I'll appreciate to read the solution.
aarendonh
3 Replies Last Post Mar 13, 2012, 3:32 a.m. EDT
Posted: 1 decade ago Mar 13, 2012, 2:29 a.m. EDT
Try a View - Destopt Layout - Reset Desktop to get a screen layout as the default one (it does not change any preferences so no danger ;)
If you double click on the borders many windows will expand or contract
Hi Try a View - Destopt Layout - Reset Desktop to get a screen layout as the default one (it does not change any preferences so no danger ;) If you double click on the borders many windows will expand or contract -- Good luck Ivar
Posted: 1 decade ago Mar 13, 2012, 2:37 a.m. EDT
Hi Mr. Ivar,
Thanks for your reply, I tried already your suggestion, but it did not fix it.
Also I tried uninstalling and re-installing it, but it does not worked either.
Any other advice ?
Ps. I attached an image...
aarendonh
Hi Mr. Ivar, Thanks for your reply, I tried already your suggestion, but it did not fix it. Also I tried uninstalling and re-installing it, but it does not worked either. Any other advice ? Ps. I attached an image... -- aarendonh
Posted: 1 decade ago Mar 13, 2012, 3:32 a.m. EDT
then I suspect a java <=> OS issue, try support they are very helpfull ;)
Hi then I suspect a java OS issue, try support they are very helpfull ;) -- Good luck Ivar
