setting up "air" enviroment
Posted Mar 15, 2012, 11:44 a.m. EDT Geometry Version 4.2 5 Replies
I am trying to do some electrostatic study, for example, there are 2 metal block sitting on a SiO2 substrate, I want to study the electrical field between the metal blocks. so I use a work plane to represent the SiO2, then extrude, then start 2nd work plane on the top surface of SiO2, put 2 rectangles for the 2 metal blocks. and finally draw a sphere to enclose the earlier structure, and make the interior of the sphere full of air to let the whole structure sitting in air, I am not sure if I built the structure correctly because the results is kind of odd. then I tried 2nd way, this time I draw the sphere first, then try to insert a work plane inside to build my SiO2. however, COMSOL would not let me to put an work plane inside the sphere. I wonder what is the right way to build the structure.
please read the update post below.
regards,
regards,
5 Replies Last Post Mar 15, 2012, 7:35 p.m. EDT
