Using mphplot to generate plots from multiple models on the same figure.
Posted Apr 17, 2012, 9:14 a.m. EDT Interfacing, Microfluidics Version 4.2a 0 Replies
I am using COMSOL 4.2a with MATLAB to generate plot from a time-dependent model. The problem is the solution for different times is in different mph files (used time in parameter sweep). Now, I want to generate a plot for e.g. inlet velocity for all times from all mph files. With "normal" MATLAB plot function, you can hold the figure axes handle and plot on the same figure. However, I couldn't find a similar option for mphplot function of COMSOL. Is there a work around for this?
Thanks .
Hello Ershad Ahamed Chemmalasseri
