Time dependent analysis - Time to reach steady state
Posted Apr 18, 2012, 3:22 a.m. EDT Heat Transfer & Phase Change, Studies & Solvers Version 4.2 6 Replies
I am trying to model transient radiative heat transfer in a cryo vacuum chamber.
I want to know how much time it takes to reach steady state temperature in my chamber.
For the moment I do a time-dependent analysis on a huge time period but I think that there are simpler way to do that.
Do you have any idea ?
Hello everyone,
a. Pl start with the steady state analysis and give number of iteration as a high value as the problem is highly non-linear.
b. Then try for the transient state with the less output interval, so that computational time will get reduced.
Ramamoorthy V
I don't understand correctly what you explained.
I have initial conditions (different from the steady-state solution), then I should do a steady-state analysis with enough iterations in order to capture it. This I understand
However I don't understand the part on the time-dependent analysis what do you mean by "less output interval"?
Thank you for your answer.
a. Why are you performing a transient state analysis, and why not steady state analysis.
b. Generally transient radiation problem wil take huge time.
c. If you could solve using steady state analysis, that results holds good.
Ramamoorthy V
The output interval described in a previous post is the info you put in the “Times” input in the Time Dependent solver node.
Nagi Elabbasi
Veryst Engineering
i guess the HUGE TIME PERIOD that you are talking about .. should be in terms of few days ...
but that should not matter.
Start with steady state analysis for having an idea of your final values.
Then compute transience for a very short period ( time interval being your own choice)
and finally complete the full computation for the required time period based on the result that you obtained for limited time interval evaluation. This is how i did my problem which is a surface to sruface radiation module based thermal calculations inside a furnace !
I am aware that the cooling time by radiation is quiet high, and I did firstly a steady-state analysis.
I deduce from your answer that there is no way to impose to a transient analysis to stop when it reaches steady-state, am I correct?
Thank you again!
