how to draw half circle
i want to draw full circle but i need to divide full circle in to two half circles ,because for one circle i have to give silicon as a subdomain setting and another half circle i have to give air as a subdomain setting, is it possible please explain in details
1 Reply Last Post Apr 19, 2012, 6:03 a.m. EDT
Posted: 1 decade ago Apr 19, 2012, 6:03 a.m. EDT
if you have two volumes or areas (in 2D) that overlap then you will get 2 distinct entities, hence you can select left and right half circles. If you add a line over a circle, and combine it into one object, you will have a cut circle
Hi if you have two volumes or areas (in 2D) that overlap then you will get 2 distinct entities, hence you can select left and right half circles. If you add a line over a circle, and combine it into one object, you will have a cut circle -- Good luck Ivar
