Hello Ming-Yi Yen
Jan 27, 2013, 1:26 p.m. EST
I have the same problem when trying to use the k-omega turbulence model. The problem doesn't occur when using the k-epsilon model, but the k-epsilon crashes because the solution diverges. At least I can get some preliminary results from the successful iterations with the k-epsilon, but I can't get a solution at my full velocity value.
Sep 23, 2013, 3:52 a.m. EDT
You need to add a new study. The old study does update correctly the solver when you change the turbulence model.
10 years ago
Sep 27, 2014, 8:49 p.m. EDT
This is great. Thanks Stanimir. It solved my problem.
9 years ago
May 14, 2015, 2:28 p.m. EDT
Hi Yi Ming
i am facing the same problem , i am trying to study converging diverging nozzle with high mach number at the exit.
can you suggest, if you found any solution around your problem.
or if you can send your model for reference , it would be really helpful for me.
regards Mehlam
Hi Yi Ming
regards Mehlam
9 years ago
Oct 19, 2015, 4:30 p.m. EDT
No solution yet?
Not even an idea about this variable?
No solution yet?
9 years ago
Nov 10, 2015, 7:23 a.m. EST
Thanks Stanimir. I had also same problem but ı solved now, ı want to say hat thanks again :D
