Material properties
Hello !
I have a question.
if I put pressure on the model, do material properties change ? as the elasticity. why does frequency change
Can someone help me ?
1 Reply Last Post Apr 24, 2012, 2:48 p.m. EDT
Posted: 1 decade ago Apr 24, 2012, 2:48 p.m. EDT
that depends what you are modelling, you might be in "solid" then you can get stress stiffening, in certain cases, but for that you need to combine a stationary stres analysis and use that as the starting point for an eigenfrequency analysis
But yu can also have a pressure dependent material that depends on the material you are using and the physics you have selected
Hi that depends what you are modelling, you might be in "solid" then you can get stress stiffening, in certain cases, but for that you need to combine a stationary stres analysis and use that as the starting point for an eigenfrequency analysis But yu can also have a pressure dependent material that depends on the material you are using and the physics you have selected -- Good luck Ivar
