Christopher Boucher
COMSOL Employee
3 years ago
Feb 23, 2021, 9:57 a.m. EST
Updated:
3 years ago
Feb 23, 2021, 9:58 a.m. EST
Hi Niek,
You can see the examples "Quadrupole Mass Filter" and "Quadrupole Mass Spectrometer" which show how to define forces on the particles that are taken from two different physics interfaces and solved for in two different studies:
https://www.comsol.com/model/quadrupole-mass-spectrometer-10653
https://www.comsol.com/model/quadrupole-mass-filter-12039
The main idea is to use the first solution as the "Values of Variables not Solved For" in the second study, and then to use the second solution as the "Values of Variables not Solved For" in the third. So the first solution gets passed to the third study indirectly, through the second.
Chris
Hi Niek,
Chris
Niek
Applied Nuclear Physics
3 years ago
Feb 25, 2021, 6:02 a.m. EST
Hi Chris,
Thank you for your reply.
So I will need three studies?
1. E field solver (S)
2. B field solver (S)
3. cpt solver (TD)
I do understand what you mean, but it does not seem to work. I feel like there is something going wrong in the cpt module, connecting both MF and particle tracing.
See the attached file, sorry for the messy results section.
I am trying to first solve the EFIELD_solver then the BField solver study (input from Efield solution as dep. var) and connect them in the particle_tracing study (input from BField solution as dep. var.).
Hi Chris,
3. cpt solver (TD)
Niek
3 years ago
Feb 26, 2021, 3:26 a.m. EST
Update.
I managed to do it now.
Make a stationairy study that solved both the E-field and the B-field:
Physics and Variables Selection --> Physics Interface--> solve for --> electrostatics (es) & Magnetic Fields (mf)
Physics and Variables Selection --> Multiphysics Coupling --> solve for --> Electric & Magnetic Particle field interaction
Use this static field solution for both fields as input solution for a time dependent cpt study:
Physics and Variables Selection --> Physics Interface--> solve for --> Charged Particle Tracing
Values of Dependent Variables --> Values of variables not solved for --> Settings (user controlled) --> method (solution) --> study (E&B Field, stationary)
The E&B Field stationary being the static field solution from above.
Update.
**Make a stationairy study that solved both the E-field and the B-field:**
**Use this static field solution for both fields as input solution for a time dependent cpt study:**
