Square wave AC source in AC/DC module for a transient simulation
It looks like there is only sine wave input available. One could use diodes to cut the
waveform to make it a square. But that seems to lead for difficulties to find a numerical solution
in simulations. In general I would need a pulse width modulated signal. How
this could be done in Multiphysics ? A good example would be the best advise. I'm still searching
a better documentation for the Spice import feature.
1 Reply Last Post May 8, 2012, 8:02 a.m. EDT
Posted: 1 decade ago May 8, 2012, 8:02 a.m. EDT
you can combine functions in v4.2a, and for certain you can add the "make periodic" such that a square pulse with rounded corners in aperiodic way is possible, worst case try to pass via an analytical function
Hi you can combine functions in v4.2a, and for certain you can add the "make periodic" such that a square pulse with rounded corners in aperiodic way is possible, worst case try to pass via an analytical function -- Good luck Ivar
