Swapping axes on 2D-surface plot
Hi, I have a problem with building plots for my time-dependent simulation. By taking a cut-line dataset, using parametric extrusion 1D and creating a surface plot from the final dataset i got a nice time-space plot. To make this more comparable to other results I would like to get the time axis on x and the space axis on y, like it is easily done with 1D plots. I could not find any well functioning way to achieve this, did i miss something?
Thanks in advance.
1 Reply Last Post Apr 4, 2021, 6:07 p.m. EDT
Posted: 4 years ago Apr 4, 2021, 6:07 p.m. EDT
Updated: 4 years ago Apr 4, 2021, 6:42 p.m. EDT
Edited: You can easily plot quantities vs. time or even time vs. quantities (by swapping the expressions in the x-Data and y-Data fields), in 1 D type plots. Even easier, for some of these 1D plots, is to check a box under the Settings panel that says "Flip the x- and y-axes." But for a "surface" plot, this action may be a bit trickier to accomplish. I expect it to be possible. Consider posting your model to the forum so we can all take a look at it.
Edited: You can easily plot quantities vs. time or even time vs. quantities (by swapping the expressions in the x-Data and y-Data fields), in 1 D type plots. Even easier, for some of these 1D plots, is to check a box under the Settings panel that says "Flip the x- and y-axes." But for a "surface" plot, this action *may* be a bit trickier to accomplish. I expect it to be possible. Consider posting your model to the forum so we can all take a look at it.
