Robert Koslover
Certified Consultant
3 years ago
Apr 8, 2021, 10:23 a.m. EDT
Updated:
3 years ago
Apr 8, 2021, 10:24 a.m. EDT
I suggest you integrate a Boolean expression across a larger volume that includes the volume of interest to you. You need to set up your Boolean expression to evaluate to 1 (aka, true) wherever the quantity of interest to you falls within the desired range of values, and 0 (aka, false) wherever the quantity of interest to you falls outside of the desired range of values. Integration can be done via post-processing under Results, or can be set up as a probe.
Gunnar Andersson
COMSOL Employee
3 years ago
Apr 9, 2021, 6:56 a.m. EDT
Robert's advice is the right solution in 5.3a.
In 5.5 and 5.6 you can get a more accurate result by creating a Filter dataset that extracts the region of interest and integrating 1 over the Filter dataset.
