Insulating boundary condition cannot be removed for certain surfaces
Hi everyone,
I'm encountering an issue where after explictly deleting certain surfaces from an Electrical Insulation boundary condition, they automatically reappear upon running the simulation.
  1. In the attached file, please see Component 1 -> Electric Currents -> "Probe Insulation" -> manual boundary selection entities 12 and 15.
  2. You should be able to recreate the problem by removing entities 12 and 15 from the boundary selection, clicking Compute (should take ~30s), and then checking that they have reappeared upon the simulation finishing.
Any help would be appreciated!
Best wishes,
Ryan
2 Replies Last Post Apr 13, 2021, 7:51 p.m. EDT
Posted: 4 years ago Apr 12, 2021, 7:55 p.m. EDT
I only took a brief look at your model, but the first clue I noticed was that you have parameterized the geometry. Your specified parameters under global definitions of r_disc_1 etc. are different than the ones in the parametric sweeps. This can be ok, but it can also cause trouble. In your case, it is causing trouble, modifying the geometry to cause your boundary conditions to be improperly defined. If you make it so they don't change, your problem goes away!
I only took a brief look at your model, but the first clue I noticed was that you have *parameterized the geometry*. Your specified parameters under global definitions of r_disc_1 etc. are *different* than the ones in the parametric sweeps. This can be ok, but it can also cause trouble. In your case, it is causing trouble, modifying the geometry to cause your boundary conditions to be improperly defined. If you make it so they don't change, your problem goes away!
Posted: 4 years ago Apr 13, 2021, 7:51 p.m. EDT
Updated: 4 years ago Apr 14, 2021, 4:51 a.m. EDT
Thanks so much Robert! If I am understanding you correctly, the issue is stemming from the geometry changing upon running a sweep?
Unfortunately I am hoping to loop through various (~200) radii combinations using the parametric sweep function (I set everything to 10mm just as a demonstration), and was wondering if you would have suggestions for how to achieve this?
Thanks so much Robert! If I am understanding you correctly, the issue is stemming from the geometry changing upon running a sweep? Unfortunately I am hoping to loop through various (~200) radii combinations using the parametric sweep function (I set everything to 10mm just as a demonstration), and was wondering if you would have suggestions for how to achieve this?
