fiber
a
4 Replies Last Post Dec 17, 2012, 2:31 p.m. EST
Posted: 1 decade ago May 20, 2012, 9:14 a.m. EDT
I suspect its your .r^2 .r I assume you mean *r^2 and *r, no ?
Hi I suspect its your .r^2 .r I assume you mean *r^2 and *r, no ? -- Good luck Ivar
Posted: 1 decade ago May 20, 2012, 9:53 a.m. EDT
yes Ivar its *r. Moreover I should use d(Ez,r) for differentiation. i have changed this but i get zero answer. probably its not understanding radial derivative. whats the way to implement that.
thanks
Deepak
yes Ivar its *r. Moreover I should use d(Ez,r) for differentiation. i have changed this but i get zero answer. probably its not understanding radial derivative. whats the way to implement that. thanks Deepak
Posted: 1 decade ago May 20, 2012, 10:40 a.m. EDT
you need to write out the cylindrical coordinate differential from the x and y derivatives. By the way normally you have alread Exx and Exy ... defined
you can define a cylindrical coordinate system to express your sys2.r
Unfortunately COMSOL does not understand d(Ex,sys2.r)
You could also then consider using a higher discretization order to try to get smoother results
Hi you need to write out the cylindrical coordinate differential from the x and y derivatives. By the way normally you have alread Exx and Exy ... defined you can define a cylindrical coordinate system to express your sys2.r Unfortunately COMSOL does not understand d(Ex,sys2.r) You could also then consider using a higher discretization order to try to get smoother results -- Good luck Ivar
Posted: 1 decade ago Dec 17, 2012, 2:31 p.m. EST
Could u give me the file on bending fiber in v 4.2.
Thanks in advance.
Could u give me the file on bending fiber in v 4.2. Thanks in advance.
