Robert Koslover
Certified Consultant
4 years ago
Jun 1, 2021, 12:13 p.m. EDT
You say
"...when it receives a planar EM wave from the air. I'm using port to model the EM wave."
That seems an odd choice to me, because if I were creating a model with an incident plane wave, I would use the scattered-field formalism (see attached image), if practical. Have you considered doing that?
You say
That seems an odd choice to me, because if I were creating a model with an incident plane wave, I would use the *scattered-field formalism* (see attached image), if practical. Have you considered doing that?
4 years ago
Jun 1, 2021, 1:59 p.m. EDT
Hi Robert,
Thank you so much for your reply. I hadn't considered that.
I might have worded it incorrectly as I'm new to this field. To give a clearer picture, what I'm trying to achieve is similar to what was designed in this video https://www.comsol.com/video/simulating-metamaterials-in-the-terahertz-regime-with-comsol-multiphysics except that I am looking to insert an inductor and capacitor surface mounted device between the gap in the middle, or anywhere really as I don't think it affects the result, device. Additionally, there would be no ground plane as the the wave is meant to pass through to a receiving antenna on the other side, so I would also insert a second port beneath the metamaterial.
In the video they use port to model the incident wave, so I did the same as I had also seen it be done in this tutorial https://www.comsol.com/model/frequency-selective-surface-periodic-complementary-split-ring-resonator-15711. Is it possible to combine lumped elements and port features in this way? or is there another approach I should take?
Hi Robert,
Robert Koslover
4 years ago
Jun 1, 2021, 3:45 p.m. EDT
Updated:
4 years ago
Jun 1, 2021, 3:47 p.m. EDT
That's a little different than what I thought you were trying to do. I've only done very little work with metamaterials. I encourage those with more experience in that area to respond to your updated questions.
4 years ago
Jun 1, 2021, 4:27 p.m. EDT
That's alright, thank you very much. Outside of this specific case, do you know if the lumped element feature is designed to work with port as well or does it only function properly when lumped port is used? I haven't been able to find any documentation that can verify this.
