Defining a path for a heat-source by use of functions
Hi everyone, I want to define a path for my heat source since it is moving on the surface. The path is definied with the given functions in x and y- axis.
start point is (0,0,0) if x=0 then x=Vt x if x=30 then x=-vt
and for y is if x=0 or 30 then y=0.1[mm] + y0
y if 0<x<30 then y=y0
  in other words,
  It starts from 0 travels with the velocity of V in the x axis until it reaches the 30 [mm] then it adds 0.1[mm] to y value and travels with same velocity but in negative direction until it reaches x=0 and again it adds 0.1[mm] to y until it reaches the last point of the surface.
  How can I define my functions and which functions should I use?
  Best Regards,
  Omid
0 Replies Last Post Jun 4, 2021, 7:58 a.m. EDT
Hello Omid Oveisi Oskouei
