4 years ago
Aug 9, 2021, 8:19 a.m. EDT
you will need to add the circuit option to the physics. i attached a screen shot of what needs to be done based on limited information. it should get you started. in ec, you add a terminal and change it to use a circuit. you then need to add a voltage source and an external coupling feature to the circuit node.
4 years ago
Aug 9, 2021, 3:08 p.m. EDT
Hello Mr. Brown,
Thank you very much for your reply. However, I could not understand how to select nodes and what nodes "0", "1", "2" or "p", "n" mean.
I have attached the photo of the design that I am currently working on. The comsol file can be found here:
https://www.comsol.com/model/microresistor-beam-366
I want to connect positive node of the voltage source to one end and negative node to the other end of the beam, so that an AC sinusoidal current flows through the microresistor beam.
(Note: There are no semiconductors, the beam is made of Aluminium)
Kindly give me a direction how can I do that.
Ekram.
Hello Mr. Brown,
Ekram.
4 years ago
Aug 9, 2021, 4:20 p.m. EDT
you will need to understand what a netlist is and how to implement it. there are many tutorials on the internet that show this. probably a lot of youtube videos as well.
here is one example:
https://www.allaboutcircuits.com/textbook/reference/chpt-7/example-circuits-and-netlists/
from your picture, it seems you want to apply a source to a floating object. i would suggest setting up the problem to ground one side to get something running. you would then have to modify the simulation to suit your needs. in any case, you will need two terminals in the physics similar to what i showed. you will also need to use two couplings.
Edgar J. Kaiser
Certified Consultant
4 years ago
Aug 10, 2021, 4:25 a.m. EDT
Updated:
4 years ago
Aug 10, 2021, 4:40 a.m. EDT
Ekram,
you don't need the circuit physics. Just make the Electric Potential subnode time dependent like V0 * sin(omega * t) and run a time dependent study. Make sure the time stepping resolves the waveform.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Ekram,
Cheers
Edgar
4 years ago
Aug 10, 2021, 8:15 a.m. EDT
Thanks Edgar. After I had posted my response I had realized that circuits is not strictly needed. Hard habits die hard.
4 years ago
Aug 10, 2021, 9:16 a.m. EDT
Mr. Kaiser and Mr. Brown,
Many thanks to both of you for your valuable suggestions.
