Membrane pressure plot problem
Dear all, I have a problem with pre-stressed circular membrane resonator.
I tried to make a simulation of pre-stressed circular membrane resonator and adding additional pressure in z-direction.
I first simulated only when pre-stressed case, but my simulation data went sth wrong after I plot membrane pressure data.
It showed that the maximum pressure value is -200 MPa, which cannot be possible, so I think there should be some kind of overflow problem or kinked point which cannot be derivative.
I found the same problem in the manual "vibrating membrane" files. I add both of my file and manual file.
Please answer me how to solve this problem if anyone knows solution.
Thanks.
I attached my file. please check this.
3 Replies Last Post Aug 19, 2021, 7:05 a.m. EDT
Posted: 4 years ago Aug 19, 2021, 4:10 a.m. EDT
You probably need to upload a file to get help with this.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 4 years ago Aug 19, 2021, 7:00 a.m. EDT
What you are plotting is the pressure in the material: -1/3*trace(stress tensor). In your case -S0/thic*2/3.
If the in-plane stresses in the membrane are positive (which they always are), then the pressure is negative.
Henrik Sönnerlind
COMSOL
What you are plotting is the pressure in the material: -1/3\*trace(stress tensor). In your case -S0/thic\*2/3. If the in-plane stresses in the membrane are positive (which they always are), then the pressure is negative.
Posted: 4 years ago Aug 19, 2021, 7:05 a.m. EDT
Dear Henrik, the reason why I try to plot the pressure data is to get deflection-pressure relation.
Can you tell me how to get this relation from the simulation, if you know?
>What you are plotting is the pressure in the material: -1/3\*trace(stress tensor). In your case -S0/thic\*2/3. > >If the in-plane stresses in the membrane are positive (which they always are), then the pressure is negative. Dear Henrik, the reason why I try to plot the pressure data is to get deflection-pressure relation. Can you tell me how to get this relation from the simulation, if you know?
