Plane strain study with prescribed displacement
I tried to solve a basic problem with prescribed displacement on each boundries (u1=y et u2=x), and i don't get the good result. I don't get after solving the displacement i put. I tried several ways to write the prescribed displacement and nothing seems to work. I attach my file to this message.
I'm sorry i can't be more explicit but i'don't understand where the problem come from.
Thank you for your help.
2 Replies Last Post Jun 22, 2012, 10:36 a.m. EDT
Posted: 1 decade ago Jun 19, 2012, 6:58 a.m. EDT
Here is the file
Here is the file
Posted: 1 decade ago Jun 22, 2012, 10:36 a.m. EDT
I would rather ask what are you trying to do, and aren't you confusing space coordinates x,y,z and displacement u,v,w ?
Anyhow if you squeeze a 5m side cube by 2.5 m in all direction you end up with a point, that is a severe topology change than no programme, norm any simple math can handle, at least not like this
The prescribed displacement is differential distance so use rather 0.1% of the side length (strain) to stay within a reasonable elastic limit. then check only one direction (normal to the boundary) and leave the other unchecked (free to change, else you are getting a strange skewed thing
Hi I would rather ask what are you trying to do, and aren't you confusing space coordinates x,y,z and displacement u,v,w ? Anyhow if you squeeze a 5m side cube by 2.5 m in all direction you end up with a point, that is a severe topology change than no programme, norm any simple math can handle, at least not like this The prescribed displacement is differential distance so use rather 0.1% of the side length (strain) to stay within a reasonable elastic limit. then check only one direction (normal to the boundary) and leave the other unchecked (free to change, else you are getting a strange skewed thing -- Good luck Ivar
