Error-System matrix is zero
Failed to find a solution.
System matrix is zero.
Returned solution is not converged.
Can anyone please explain me about this error?
5 Replies Last Post Sep 9, 2013, 5:56 a.m. EDT
Posted: 1 decade ago Jun 22, 2012, 5:04 a.m. EDT
most often it is because you are missing A BC or you have not fully defined the solution. Particularly, when you have many physics, you need enough BC for ALL physics independently. else the solution is not unique.
Hi most often it is because you are missing A BC or you have not fully defined the solution. Particularly, when you have many physics, you need enough BC for ALL physics independently. else the solution is not unique. -- Good luck Ivar
Posted: 1 decade ago Jul 2, 2012, 6:20 p.m. EDT
Thank you.
Thank you.
Posted: 1 decade ago Mar 28, 2013, 10:36 p.m. EDT
Could you please tell me what A,B and C stand for? Thank you very much~
Posted: 1 decade ago Mar 29, 2013, 3:43 a.m. EDT
Sorry, I was typing to quick ;)
I intended to write "...a BC (Boundary Condition) ..."
Hi Sorry, I was typing to quick ;) I intended to write "...a BC (Boundary Condition) ..." -- Good luck Ivar
Posted: 1 decade ago Sep 9, 2013, 5:56 a.m. EDT
Sir
I am doing a coiled heat exchanger problem, I have defined all the boundary conditions-viz- temperature, fluid velocity, material properties but still this error ocuurs. Tell me how can I rectify this.
Sir I am doing a coiled heat exchanger problem, I have defined all the boundary conditions-viz- temperature, fluid velocity, material properties but still this error ocuurs. Tell me how can I rectify this.
