Piezoelectric cantilever based energy harvester- body load notation query
Hello everyone,
I have desined a 3D multilayered cantilever piezoelectric structure. I have clearly defined the materials and assigned it to its respective domain.
I have to simulate it for vertical body acceleration.
In the existing piezoelectric energy model (this is in 2D) in application library, the body load is given as solid.rho*g_const*acc.
I have done the same for my 3D structure. But I am getting the error showing "undefined variable" "failed to evaluate variable".
Can anyone solve this query??
2 Replies Last Post Oct 6, 2021, 9:43 a.m. EDT
Magnus Ringh COMSOL Employee
Posted: 4 years ago Oct 6, 2021, 7:44 a.m. EDT
You get this error because the Solid Mechanics interface in the model is called Solid Mechanics 2, with the tag solid2. So, changing the expression to -solid2.rho*g_const*acc in the Settings window for the Body Load node makes the simulation run.
Magnus
Hi, You get this error because the Solid Mechanics interface in the model is called **Solid Mechanics 2**, with the tag `solid2`. So, changing the expression to `-solid2.rho*g_const*acc` in the Settings window for the **Body Load** node makes the simulation run. Best regards, Magnus
Posted: 4 years ago Oct 6, 2021, 9:43 a.m. EDT
Hi Magnus,
Thank you very much for the reply.
But now, it showing error as "There are 1 void equations (empty rows in matrix) for the variable comp1.es.term1.Q0_ode. at coordinates: (0,0)" and "return solution is not converged"
I have connected the ground to the lower face of PZT and other terminal at the top face of PZT. And i have included the electric circuit as well.
Thanks.
Hi Magnus, Thank you very much for the reply. But now, it showing error as "There are 1 void equations (empty rows in matrix) for the variable comp1.es.term1.Q0_ode. at coordinates: (0,0)" and "return solution is not converged" I have connected the ground to the lower face of PZT and other terminal at the top face of PZT. And i have included the electric circuit as well. Thanks.
