Jun 27, 2012, 12:55 p.m. EDT
there are two ways: either you know the pressure field spatially and temporally (or in frequency content) and you apply this as a boundary pressure load to your Solid (structure physics),
Or you go for a full FSI (fluid-structure interface) physics which is far heavier but gives a coupled interaction: the wind pushes the structure that changes the wind shape etc.
But a more complex model means more time to set it up, to run it, and to validate it, not to say larger computer(s), you might need a cluster depending on your model size
Jun 28, 2012, 7:03 a.m. EDT
Thank you, for your advise, its much appreciated.
I'll give it a go.
I'll give it a go.
