Permanent magnet force calculation error
Hello everybody,
I'm trying to compute the force between a sphere permanent magnet and a iron ball.
The system is successfully solved but when i try to compute the force I get a lot of failed to evaluate variable errors.
Anybody has an idea why I get this error?
Model is attached.
5 Replies Last Post Jul 4, 2012, 7:39 a.m. EDT
Posted: 1 decade ago Jul 3, 2012, 9:27 a.m. EDT
if you include the total force of source and destination = magnet and iattracted ron you should get a net "0" or thereabout. What about trying to solve for two forces, one for each shpere and compare the two (with opposed signes)
Hi if you include the total force of source and destination = magnet and iattracted ron you should get a net "0" or thereabout. What about trying to solve for two forces, one for each shpere and compare the two (with opposed signes) -- Good luck Ivar
Posted: 1 decade ago Jul 3, 2012, 9:46 a.m. EDT
Thank you for your reply.
I don't get any result, I get the error message that the variable dnphi cannot be evaluated at the boundaries of the sphere no matter which sphere I choose.
The thing worked in 3 d, but I wanted to save computing force, so I did it in 2d axisymmetric.
The name of the variable (dnphi) shows also that I have probably done something wrong with the 2d axisymmtric geometry.
Thank you for your reply. I don't get any result, I get the error message that the variable dnphi cannot be evaluated at the boundaries of the sphere no matter which sphere I choose. The thing worked in 3 d, but I wanted to save computing force, so I did it in 2d axisymmetric. The name of the variable (dnphi) shows also that I have probably done something wrong with the 2d axisymmtric geometry.
Posted: 1 decade ago Jul 4, 2012, 3:04 a.m. EDT
it did solve OK for me but I have v4.3, when I split the force (with different 2 names) into two.
But, I noticed that the error(differences) was quite large, I didnt have time to check out why. Back in 4.2 sometimes I got more preciese results with MF rather than MFNC, even if I had no curent. And from v3.5 I know that force estimation is very mesh density and mesh shape dependent
Hi it did solve OK for me but I have v4.3, when I split the force (with different 2 names) into two. But, I noticed that the error(differences) was quite large, I didnt have time to check out why. Back in 4.2 sometimes I got more preciese results with MF rather than MFNC, even if I had no curent. And from v3.5 I know that force estimation is very mesh density and mesh shape dependent -- Good luck Ivar
Posted: 1 decade ago Jul 4, 2012, 7:17 a.m. EDT
Thank you, it worked when I took MF.
Posted: 1 decade ago Jul 4, 2012, 7:39 a.m. EDT
Interesting, I wounder what is so different between MF and MFNC, in case you find out pls report back
Hi Interesting, I wounder what is so different between MF and MFNC, in case you find out pls report back -- Good luck Ivar
