Feb 4, 2010, 12:59 a.m. EST
I can (again) insist: read carefully the documentation a couple of times and do the exercises, when you are a newcomer, I know it's more fun to try out your own cases, but you will progress quicker that way.
Anyhow I hop I can give you some replies:
1) the difference between imposed temperature and T and a heat source Q, well in one case you do as said: impose the temperature independently of how much power is required, the power is adapted implicitely to get the imposed temperature. If you do this on a volume, you will see no gradients, if you do this on a edge /surface of a volume you might get temperature differences in a temporal analysis, and if you do not impose any losses you will also see a constant temperature for a stationary analysis as you are waiting an infinite long time, which allows the temperature to settle everywhere.
In a transient analysis (depending on "t" see your equations) you can define a temperature BC (boundary condition) as a function of time, what I understand you do.
2) imposing the "Q" heat source (or sink depends on sign) you input some energy, possibly with a time variation, that is transfomed into heat (hence a temperature change) via the material heat capacity and its density (check the units they are very usefull to helpt to get the logic right). Imposing a volume=subdomain heat source is an even energy distributed over the subdomain, if you apply it on a boundary it's like heating the surface with an external heatsource. With a heat source and sink you get about always T gradients, in stationary and in the time domain analysis.
By the way, when you look at the time dependent plots, do no forget to select the moment of interest in the postprocessing plot general tab
