Henrik Sönnerlind
COMSOL Employee
3 years ago
Nov 16, 2021, 3:45 a.m. EST
Frequency domain analysis has the fundamental assumption that all quantities, excitation as well as response, are harmonic. This is not the case in a nonlinear system.
The only way to study a nonlinear system is in time domain. You can, however, use a linear frequency domain analysis to set up reasonable initial values for the time domain analysis. In that way, it takes less time to converge to a cyclic solution in time domain. You can still, however, expect to have to run the analysis for many cycles, in particular if the damping is low.
Henrik Sönnerlind
COMSOL
3 years ago
Nov 16, 2021, 9:53 a.m. EST
Thanks Henrik for your timely response. Are there any examples you'd recommend me to look at with regard to this?
Henrik Sönnerlind
COMSOL Employee
3 years ago
Nov 19, 2021, 3:07 a.m. EST
I am not aware of such a model, but in principle you do the following:
- Two study steps, the first is Frequency Domain and the second is Time Dependent.
- Add a suitable load to be used in the frequency domain study. Typically, this is the same load as you would use later in the time domain study, but without the sin(omega*t) factor.
- Add the same load with the sin(omega*t) factor.
- In the Initial Values node, write displacement as imag(u) etc., and velocity as omega*real(u)
- In the studies, disable the non-used load for each study.
- Make sure that for the frequency domain study, the Stationary Solver has Linearity set to Linear.
Note: The exact use of real() and imag() and the signs in front of the operators depend on how you consider your time depence. In frequency domain, a quantity having no explicit phase is assumed have an implicit cos(omega*t)
Providing an example of this approach seems like a good idea. I have added such a suggestion.
Henrik Sönnerlind
COMSOL
1. Two study steps, the first is Frequency Domain and the second is Time Dependent.
2. Add a suitable load to be used in the frequency domain study. Typically, this is the same load as you would use later in the time domain study, but without the sin(omega\*t) factor.
3. Add the same load with the sin(omega\*t) factor.
4. In the Initial Values node, write displacement as imag(u) etc., and velocity as omega\*real(u)
5. In the studies, disable the non-used load for each study.
6. Make sure that for the frequency domain study, the Stationary Solver has Linearity set to Linear.
Note: The exact use of real() and imag() and the signs in front of the operators depend on how you consider your time depence. In frequency domain, a quantity having no explicit phase is assumed have an implicit cos(omega\*t)
