Jul 6, 2012, 9:29 p.m. EDT
Could u explain it properly, wht kind of reactions are u trying solve, and u can also put few pics of your model, if u don't want to share ur model in explaining it.
9 years ago
May 20, 2016, 2:18 p.m. EDT
Hello Kelley,
I am relatively new to COMSOL and am running a very similar simulation and having the same difficulty you mentioned in your post. Did you ever get this issue solved? If so I'd love to have some guidance on how I might be able to correct my simulation.
Hello Kelley,
Walter Frei
COMSOL Employee
9 years ago
May 20, 2016, 3:08 p.m. EDT
Dear Kelly, Joshua,
What you are describing can be done with the Chemical Reaction Engineering Module.
Please see, for example:
www.comsol.com/model/protein-adsorption-1397
And, for a basic introductory example which shows how to manually enter governing equations if you do not have the Chemical Reaction Engineering Module, see:
www.comsol.com/model/transport-and-adsorption-5
Best Regards,
Dear Kelly, Joshua,
https://www.comsol.com/model/protein-adsorption-1397
https://www.comsol.com/model/transport-and-adsorption-5
Best Regards,
9 years ago
May 20, 2016, 3:29 p.m. EDT
Walter,
I appreciate the help but unfortunately I am unable to open your models as I am running 4.3a. Do you have any models that would run on that version?
The simulation I am running is a fluid flow running through a cylindrical chamber from an inlet, hitting a sphere, going around the sphere, then leaving through an outlet. I am running a time-dependent study with the physics laminar flow and transport of diluted species. Currently, I have species A coming in as an inflow and I would like the local concentration of species A on the surface of the sphere (inside the cylindrical channel) to determine how much of Species B is released from the sphere.
Is there a way I can simulate this if I only have the Microfluidics Module purchased?
Thanks again,
Josh
Walter,
Thanks again,
Josh
Walter Frei
COMSOL Employee
9 years ago
May 20, 2016, 5:31 p.m. EDT
Dear Josh,
We do of course encourage you to come back on subscription, and to upgrade to one of the Modules that support surface reactions. See
www.comsol.com/products/specifications/chemical/ for a listing of what features are available in which Modules.
Also, take a look over the step-by-step instructions in the second example (
www.comsol.com/model/transport-and-adsorption-5) you should be able to reproduce these in any recent version of the software.
Best Regards,
Dear Josh,
We do of course encourage you to come back on subscription, and to upgrade to one of the Modules that support surface reactions. See https://www.comsol.com/products/specifications/chemical/ for a listing of what features are available in which Modules.
Also, take a look over the step-by-step instructions in the second example (https://www.comsol.com/model/transport-and-adsorption-5) you should be able to reproduce these in any recent version of the software.
Best Regards,
8 years ago
Nov 11, 2016, 4:40 p.m. EST
Hi Walter,
In the "
www.comsol.com/model/transport-and-adsorption-5" model you suggested, the chemical reaction is on a one-dimensional surface. If the surface is a sphere (3D), how would you formulate the PDE? Will that be similar to the model?
Thank you in advance.
Hi Walter,
In the "https://www.comsol.com/model/transport-and-adsorption-5" model you suggested, the chemical reaction is on a one-dimensional surface. If the surface is a sphere (3D), how would you formulate the PDE? Will that be similar to the model?
