Radiated power of an electric dipole in free space
I am working on a simulation of an electic dipole(point source) with dipole moment of 1 Am, which oscillates harmonically with a frequency of 8,444910^14 Hz in free space. I am interested in evaluating the Green tensor in a 3D model. However, during the simulation the emitted radiated power is in the power 10^(15) W instead of 10^(46) W which is the correct result according to the bibliography. Has anybody encountered a similar problem while simulating electric dipoles behaving like a point source?
Thank you.
2 Replies Last Post Dec 13, 2021, 8:33 a.m. EST
Posted: 3 years ago Dec 11, 2021, 7:02 p.m. EST
Updated: 3 years ago Dec 11, 2021, 8:03 p.m. EST
You probably either did your arithmetic incorrectly or used the wrong equation. (After all, 10^46 W is greater than the power output of a supernova.) Regardless, you'll be happy to learn that your simulation gave the correct result to within 1%. Among others, you could take a look at page 16, equation 1-74, in Antenna Theory and Design by W.L. Stutzman and G.A. Thiele, published by John Wiley & Sons, 1981. The equation there will yield P = 10^15 W if using your numbers.
p.s. A static electric dipole moment, p, has units of charge x distance. The dipole moment that you refer to is in terms of current x distance. This is not the same thing, of course. Confusing the two leads to the error you reported.
You probably either did your arithmetic incorrectly or used the wrong equation. (After all, 10^46 W is greater than the power output of a supernova.) Regardless, you'll be happy to learn that your simulation gave the correct result to within 1%. Among others, you could take a look at page 16, equation 1-74, in *Antenna Theory and Design* by W.L. Stutzman and G.A. Thiele, published by John Wiley & Sons, 1981. The equation there will yield P = 10^15 W if using your numbers. p.s. A static electric dipole moment, *p*, has units of *charge* x distance. The dipole moment that you refer to is in terms of *current* x distance. This is not the same thing, of course. Confusing the two leads to the error you reported.
Posted: 3 years ago Dec 13, 2021, 8:33 a.m. EST
Thanks a lot for your help!
