How to calculate convective and radiative heat flux ?
I am trying to understand the method to calculate convective heat transfer and radiative heat transfer in comsol. The geometry is a simple rectangle (2D case). Two opposite sides are insulated and other two opposite sides have heat flux boundary condition with respective temperature and h values. Material selection is air.
I have surface to surface radiation model for radiation. The two sides which have heat flux boundary condition are selected as diffuse surface and emissivity values are defined.
When I look at the results convective and radiative heat transfers are zero. But the conductive heat flux has some value. I do not understand what is going in the calculation.
Can someone explain how to find these values?
Thank you.
1 Reply Last Post Dec 22, 2021, 8:34 a.m. EST
Posted: 3 years ago Dec 22, 2021, 8:34 a.m. EST
In fact, convective flux accounts for displacement of fluid, which is achieved with Non-isothermal multiphysics, with Laminar or Turbulent Flow physics. In the solid-fluid boundary, heat flux is accounted simply as Normal conduction.
Hello, In fact, convective flux accounts for displacement of fluid, which is achieved with Non-isothermal multiphysics, with Laminar or Turbulent Flow physics. In the solid-fluid boundary, heat flux is accounted simply as Normal conduction.
