How to use a rotational transformation of a solution as an input for another study?
Posted Dec 16, 2021, 11:43 a.m. EST Acoustics & Vibrations, Heat Transfer & Phase Change, Results & Visualization Version 5.5 0 Replies
Hi, I'm planning to model an flat piezoelectric (PZT) transducer emitting energy in a biological tissue and then calculate the temperature profile. The PZT will rotate fast. I would like to know if it is possible to solve the acoustic problem with a fixed (non rotating) PZT, then apply a rotational transformation to the acoustic power density to mimic the rotating PZT, and then use that transformation to solve for the temperature profile. As far as I understand, the transformations available in the Dataset node are for post-processing only and are not accessible in the study nodes. Please let me know if there is a way to achieve what I'm proposing. Thanks.
Hello Dany Berube
