Bug in parametric geometry?
Hello, I had very simple parametric model, I have set up the parameters first by hand, then I refreshed like this: 1 - delete those parameters from the parameter table 2 - import them again from an external .txt file Voila, some of the geometry did not update: 2 circles in the geometry had a wrong radius. I had to add +1[mm] to their radius in the Circle geometry node, click "Build selected", then remove the +1[mm], build again, and it was then ok. The model is now correct, so I can not attach the example. Is this a bug or a feature? Or am I updating the parameter list in a non-allowed way - but it should then not be possible at all... thank you
0 Replies Last Post Dec 29, 2021, 6:18 a.m. EST
Hello Daniel Barna
