error in the model of a coax
Posted Jul 11, 2012, 2:37 p.m. EDT Low-Frequency Electromagnetics 1 Reply
I'm a newbie on comsol, trying to model in ac/dc module and electromagnetics.
I started to work with a simple coax cable structure, examined the capacitance wrt radius of insulator as well as different different types of insulators in electrostatics physics. Then studied the tutorial on the empedance of a coax cable.
Now, what I want to is to apply an ac voltage to its conductors and see how it behaves.
However I couldn't do it. First, I solved the problem in time domain of electrostatics and electric currents separately, as seting the terminal voltage a function depended on time, i.e. Vo*sin(2*pi*f*t).
When those did not work, I switched to the freq.domain in electric currents. However, that did not work, either.
This is the error I'm getting,
Problem encountered during results while solving.
Evaluation of result expression failed.
Failed to evaluate variable.
- Variable: es.nD
- Geometry: 1
- Boundary: 6 7 8 9 10 11 26 27 28 42 43 44
- Expression: real(es.nD)
What might be the problem?
thanks a lot
CBD
- Variable: es.nD
- Geometry: 1
thanks a lot
CBD
1 Reply Last Post Jul 12, 2012, 3:39 p.m. EDT
