Variable Exchange - Model Coupling
Posted Jul 22, 2012, 12:15 p.m. EDT 3 Replies
Hi all,
I am trying to solve a fluid flow through a porous medium. Where I modeled the fluid flow and overall heat transfer with a PDE and the heat transfer within one medium with the heat transfer module.
So I created two models in one file and now I am trying to interchange the correct variables between these two models. I guess the averaged coupling operator which I used for the second model should do the job. But I am not sure about how passing the variable from the first model to the second (Extrusion or Projection).
When looking at the result the temperature of the fluid along the length of the medium it tending to the temperature of the medium. But with progressing time the temperature rises above the initial temperature- which can not be true.
Can someone give me hint if I am using the right operators?
I attached a short explanation of the problem and my file.
Thank you for help and time, I really appreciate it.
Nic
Nic
3 Replies Last Post Jul 23, 2012, 11:47 a.m. EDT
