Operator
Is it possible to calculate the position (x) which changes over time, where for two dependent variables that change over time the following applies: h2-h1 = 0.001? Can I use the operator at1?
Alexandra
2 Replies Last Post Mar 10, 2022, 5:38 p.m. EST
Posted: 3 years ago Mar 10, 2022, 9:16 a.m. EST
Hello Alexandra,
If you know that at all times there is one and only one x where the condition h2-h1=.001 is satisfied, you could use the minimum operator to find the location of the minimum of ((h2-h1)-0.001)^2.
I am sure there's a more elegant solution, but hopefully this helps.
Jeff Hiller
Hello Alexandra, If you know that at all times there is one and only one x where the condition h2-h1=.001 is satisfied, you could use the minimum operator to find the location of the minimum of ((h2-h1)-0.001)^2. I am sure there's a more elegant solution, but hopefully this helps. Best, Jeff
Posted: 3 years ago Mar 10, 2022, 5:38 p.m. EST
Hello Jeff,
Thank you very much for the answer!
Hello Jeff, Thank you very much for the answer!
