2D interpolation of material properties as function of Temperature and Pressure?
Posted Jul 23, 2012, 7:58 p.m. EDT Version 4.2, Version 4.2a, Version 4.3 7 Replies
2. define interpolation function (say int1), use data from the file
3. make sure you defined the int. function correctly. Just click the "plot" button to plot it
4. now you can use the function int1(P,T) to define material properties. Just make sure to fix the units for P and T so the text field appears in black, not in red or yellow color.
Could you please expand on the properly defining the function int1? I have uploaded data with three columns the first column is Temperature the second column is pressure and the third is the density as as a function of the two.
Should the data for sure be in columns? and should there be column headings in the data file?
Would it be possible for you to send me a quick screenshot of how you have set up a 2D interpolation? It would be great help because I feel like I am doing everything you have stated but I am getting numerous errors related to improper number of functions and arguments, etc.
Thanks.
Chris
Have you succeeded to creat 1D interpolation?
I have some problems about how to create interpolation function on temperature-dependent thermal conductivity. I have made a .txt file with two columns (the first column is the Temperature, and the second one is thermal conductivity).
But i have no idea how to insert the text into Material Contents. I typed the function name in the blank of "Value", but the font color is always yellow. It always comes out as "The following feature has encountered a problem: Failed to evaluate variable Jacobian....."
Do you know why this happened?
1. create data file with 3 columns: P,T,f(P,T)
Thanks. Very helpful tips.
Suggested Content
- FORUM Using interpolation to define temperature-dependent material properties
- KNOWLEDGE BASE Resolving Time-Dependent Waves
- BLOG How to Use Interpolated Material Data to Model Irregular Geometries
