Mats Danielsson
COMSOL Employee
3 years ago
Mar 31, 2022, 7:50 a.m. EDT
Hello. The implementation of the JMAK phase transformation model is done on a rate form (just like the other phase transformation models in the Metal Processing Module). The rate form has been derived by differentiating the "standard" JMAK equation with respect to time. So, within the assumptions leading to this rate form, you don't have to do anything special to use the model under a thermal transient.
Mats
Mats
3 years ago
Apr 11, 2022, 12:36 a.m. EDT
Thanks Mats!
Just wanted to talk about a specific case with Ti6Al4V material. While using such material for analysising thermal based manufacturing processes (Laser etc..) for rapid cooling how should be the approach? Equilibirum phase fractions and other parameters (JMAK Exponent) will varry with temerature I believe. So can we define these arameters as Temperature depndent interpolation functions?
Thanks Mats!
Mats Danielsson
COMSOL Employee
3 years ago
Apr 13, 2022, 1:00 a.m. EDT
Hello.
In modeling the decomposition of beta into different alpha phases (like grain boundary alpha, martensitic alpha, etc.) you'll have to identify a suitable modeling framework in the literature. With this at hand, you can simply start off by adding phase transformations and metallurgical phases to the physics interface. You are correct in that parameters are generally temperature dependent. For example, in the user input for the equilibrium phase fraction, you could define an interpolation function "int1", and type something like "int1(metp.T)". The program will automatically evaluate expressions that you enter.
Mats
Hello.
Mats
3 years ago
Apr 15, 2022, 3:02 p.m. EDT
Thank You, Will Try
