Calculation of Contact area
Hi everyone!
Pardon me if this is an easy question, but I'm new to comsol. I want to use the contact area in which the amount of contact stress is greater than a specific amount as a boundary condition in a subsequent analysis. In other words, I have a structural mechanics problem in which two surfaces are in contact with each other, and I want to enforce a boundary condition (in a subsequent analysis, of course) on the portion of one of the surfaces that is experiencing contact stress higher than a specific value. How can I approach this? Any ideas? Thank you all!
2 Replies Last Post Apr 12, 2022, 10:51 a.m. EDT
Posted: 2 years ago Apr 11, 2022, 2:43 a.m. EDT
That depends on what type of boundary condition you are going to use. If it is a Neumann condition, then you can just write an expression in the input field of the type
if(withsol('sol1',solid.Tn)>my_limit),my_neumann_expression,0)
Please check the exact syntax of the withsol() operator in the documentation.
If it is a Dirichlet condition, you can in principle use the same technique, but it is a bit trickier (since the value zero does not mean 'nothing'). You can find the details in this blog post:
https://www.comsol.com/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation/
Henrik Sönnerlind
COMSOL
That depends on what type of boundary condition you are going to use. If it is a Neumann condition, then you can just write an expression in the input field of the type *if(withsol('sol1',solid.Tn)>my\_limit),my\_neumann\_expression,0)* Please check the exact syntax of the _withsol()_ operator in the documentation. If it is a Dirichlet condition, you can in principle use the same technique, but it is a bit trickier (since the value zero does not mean 'nothing'). You can find the details in this blog post:
Posted: 2 years ago Apr 12, 2022, 10:51 a.m. EDT
Thank you very much! I'm going to put your suggestion into practice and post the results.
